Hapuka 1 Posted August 24, 2021 Share Posted August 24, 2021 May have already been covered here ...... but I have a Dyneema backstay which howls like a demented mother-in-law whenever wind gets above about 15 knots. Note changes dependent on how much tension is on her (the backstay) Anyone have any experience here, or ideas on how to quieten her down? Could just go back to original wire backstay I guess. Quote Link to post Share on other sites
Black Panther 1,834 Posted August 24, 2021 Share Posted August 24, 2021 Tune it to a major chord, the minors sound too melancholy. 3 Quote Link to post Share on other sites
Dtwo 157 Posted August 24, 2021 Share Posted August 24, 2021 Ha, BP's on fire! My solution was to tie a piece of about 8mm line on. It was driving me bonkers and I just grabbed an offcut that was lying around. 3 years later and it's still there. The 8mm is only about 300mm long and just clove-hitched on. That was a spare Dyneema main halyard, not a backstay. But worth a try. Otherwise, the AC boats run a little flap on their rigging. Certainly looks a bit more Gucci. 1 Quote Link to post Share on other sites
CarpeDiem 575 Posted August 24, 2021 Share Posted August 24, 2021 39 minutes ago, Hapuka said: May have already been covered here ...... but I have a Dyneema backstay which howls like a demented mother-in-law whenever wind gets above about 15 knots. Note changes dependent on how much tension is on her (the backstay) Anyone have any experience here, or ideas on how to quieten her down? Could just go back to original wire backstay I guess. Von Karman Vortex Street - the same phenonem that causes a Chinese Gybe. https://en.m.wikipedia.org/wiki/Kármán_vortex_street You need to break up the air flow with a strake. Wrap some 0.5mm dyneema around it for about 1m at the bottom. Or put some balls on it, like a squash ball. You could also try shortening it by a few inches, reducing the harmonic length. ^^ Chimneys with strakes fitted to break up the vortices. Quote Link to post Share on other sites
Hapuka 1 Posted August 24, 2021 Author Share Posted August 24, 2021 40 minutes ago, CarpeDiem said: Von Karman Vortex Street - the same phenonem that causes a Chinese Gybe. https://en.m.wikipedia.org/wiki/Kármán_vortex_street You need to break up the air flow with a strake. Wrap some 0.5mm dyneema around it for about 1m at the bottom. Or put some balls on it, like a squash ball. You could also try shortening it by a few inches, reducing the harmonic length. ^^ Chimneys with strakes fitted to break up the vortices. Cheers CarpeDiem thats an interesting read! Great I'll try spiralling some 0.5mm around the lower metre of backstay. Although wouldnt the top section of it still produce the offending vortex? Quote Link to post Share on other sites
CarpeDiem 575 Posted August 24, 2021 Share Posted August 24, 2021 31 minutes ago, Hapuka said: Cheers CarpeDiem thats an interesting read! Great I'll try spiralling some 0.5mm around the lower metre of backstay. Although wouldnt the top section of it still produce the offending vortex? I don't know. We stopped this humming on our running back stays purely by accident when we tied a bungy in middle to pull the lazy runner out of the way. The tight bungy stopped it dead by breaking the airflow. I noticed that the AC75s seemed to all have their strakes at different heights on their runners so you might have to experiment with it at different heights.... Quote Link to post Share on other sites
CarpeDiem 575 Posted August 24, 2021 Share Posted August 24, 2021 48 minutes ago, Hapuka said: Cheers CarpeDiem thats an interesting read! Great I'll try spiralling some 0.5mm around the lower metre of backstay. Although wouldnt the top section of it still produce the offending vortex? After a bit more lockdown googling, I notice that the strake are very long, almost the full length of the thing being protected. https://www.cmrp.com/blog/bending/examples-of-vortex-shredding-mitigated-by-helical-strakes.html So this idea might not be practical. I remember racing on a tp52 out of Sydney that had this wire twisted around it all the way up the back stay, I always thought it was part of the ssb antenna until I discovered strakes.... Now that know what they are I can't stop spotting them... Eg... 1 Quote Link to post Share on other sites
Black Panther 1,834 Posted August 24, 2021 Share Posted August 24, 2021 Should work. The harmonic requires the full length of the backstay. If you effectively shorten it by tying a line to it or wrapping a bit of it as described you break up the harmonic. ( my daughter is a piano tuner). 2 Quote Link to post Share on other sites
DoT 31 Posted August 24, 2021 Share Posted August 24, 2021 Something to break up the harmonic and/or take energy out. At anchor I use the main halyard as topping lift. I tie a short length of 4mm line between the backstay and the main halyard to stop it humming, about as high up as I can reach. Maybe possible to do something between the backstay and the aft stanchions? Or how about a rubber grommet at the end to absorb some of the energy - or a pad arranged to press on the backstay the like palm muting a guitar string. 1 Quote Link to post Share on other sites
Zozza 372 Posted August 24, 2021 Share Posted August 24, 2021 Free Range Sailing have dyneema rigging that plays music too 1 Quote Link to post Share on other sites
Jon 413 Posted August 24, 2021 Share Posted August 24, 2021 Our dyneema backstay vibrates a loud harmonic through our carbon rig right into the master cabin. A sharp dig in the ribs fixes it every time. (I get up and let the backstay off completely) 3 Quote Link to post Share on other sites
armchairadmiral 411 Posted August 24, 2021 Share Posted August 24, 2021 All too hard. We went back to a SS backstay...heavier but clears the leech better too 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 24, 2021 Share Posted August 24, 2021 we have exactly this with a topping lift. The first night out we thought it was the wind generator on the cruiser parked next to us - a loud, howling vibrato. We tried all sorts of things including bungy cords and pennants, but it only modified the pitch. We gave up and the halyard now does the business once the main is down. Quote Link to post Share on other sites
waikiore 523 Posted August 24, 2021 Share Posted August 24, 2021 Of course without over thinking it you can tie your tea towel at arm high above you -after doing the dishes, havent seen it fail yet! 1 Quote Link to post Share on other sites
Dtwo 157 Posted August 25, 2021 Share Posted August 25, 2021 Try this and see if it works. It just soaks up the vibrations. 1 Quote Link to post Share on other sites
Fogg 427 Posted August 25, 2021 Share Posted August 25, 2021 Yes Karman vortices are interesting things and were a key consideration for my father when he was leading a team of supersonic aerodynamicists for the design of Hawk, Tornado and Concorde amongst others. They were a team of scientists working for UK Govt (MOD) but frequently got ‘loaned out’ to help with crucial civilian projects in UK and other friendly allies including civil aircraft (Boeing & Airbus), NASA, the big cross-channel hovercraft fans and various heavy industries eg huge scale airflows through British Steel’s furnaces etc. Quote Link to post Share on other sites
Hapuka 1 Posted August 25, 2021 Author Share Posted August 25, 2021 Brilliant thanks team... cheers for all the ideas and links! Will try them once I can get back on board. Would be interesting to know how many years a stay could survive such high frequency vibration before it failed.....! Quote Link to post Share on other sites
chariot 244 Posted August 25, 2021 Share Posted August 25, 2021 Not long in some cases. Read once of a Sydney to Hobart entrant who lost a new rig. The cause of rig failure was due to harmonics. Quote Link to post Share on other sites
