darkside 69 Posted July 22, 2022 Share Posted July 22, 2022 Hydrogen fuel cells are certainly possible if you are lucky enough to have the rate payers picking up the tab. No one else in their right mind would. Quote Link to post Share on other sites
CarpeDiem 541 Posted July 22, 2022 Share Posted July 22, 2022 1 hour ago, darkside said: Hydrogen fuel cells are certainly possible if you are lucky enough to have the rate payers picking up the tab. No one else in their right mind would. Absolutely. Also hydrogen only makes sense if you can't store enough required energy in your batteries. Otherwise it's inefficient. I am bemused to see a ex Toyota hydrogen fuel cell for sale on trademe. $25k. https://www.trademe.co.nz/3688885920 What could possibly go wrong Quote Link to post Share on other sites
Deep Purple 530 Posted July 29, 2022 Share Posted July 29, 2022 You know what's funny....Ports of Auckland recently commissioned a fully electric tug boat. They have found on delivery that they do not have the electrical infrastructure to fast charge it so they have 2 yes 2 diesel generators parked on the wharf charging it 1 Quote Link to post Share on other sites
Steve Pope 255 Posted July 29, 2022 Share Posted July 29, 2022 9 minutes ago, Deep Purple said: You know what's funny....Ports of Auckland recently commissioned a fully electric tug boat. They have found on delivery that they do not have the electrical infrastructure to fast charge it so they have 2 yes 2 diesel generators parked on the wharf charging it I have heard that at full "electric" power it can only run for 30 minutes??? Quote Link to post Share on other sites
ex Elly 268 Posted July 29, 2022 Share Posted July 29, 2022 Sparky is supposed to do 4 shipping moves, so much longer than 30 minutes. According to this: https://www.poal.co.nz/media-publications/Pages/Sparky-arrives-in-Auckland.aspx Quote Link to post Share on other sites
khayyam 101 Posted July 29, 2022 Share Posted July 29, 2022 30 minutes at full power is very different from 30 minutes of normal operation. Our 195kw ev could theoretically drain the 60 kWh battery in less than 20 minutes flat out, but in practice it will do 400km. Quote Link to post Share on other sites
CarpeDiem 541 Posted July 29, 2022 Share Posted July 29, 2022 Yep, it's 30 minutes at full rated bollard pull. Quote Link to post Share on other sites
Ex Machina 390 Posted July 29, 2022 Share Posted July 29, 2022 32 minutes ago, khayyam said: 30 minutes at full power is very different from 30 minutes of normal operation. Our 195kw ev could theoretically drain the 60 kWh battery in less than 20 minutes flat out, but in practice it will do 400km. Just put a generator in the boot and go flat out as much as you want Quote Link to post Share on other sites
CarpeDiem 541 Posted July 29, 2022 Share Posted July 29, 2022 23 hours ago, Deep Purple said: You know what's funny....Ports of Auckland recently commissioned a fully electric tug boat. They have found on delivery that they do not have the electrical infrastructure to fast charge it so they have 2 yes 2 diesel generators parked on the wharf charging it Are you sure? This sounds like a crossed/confused story... The tug isn't fully electric, it has two backup diesel generators in it for emergency. It is effectively a PHEV. Given the amount of energy they use annually I find it hard to reconcile this. Eg The 3 small port cranes have dual 373kw lift motors in each crane and these cranes can run simultaneously, that amounts to 2200kw at peak power. That energy alone is enough to charge Sparky's 2.7MWh battery in the claimed 2 hours. In 2017 the port used 16.7GWh of energy. That's enough to fully charge Sparky 5900 times. They recently installed LED lighting saving 1.17GWh per year. That saving alone was enough to charge Sparky 400 times per year... The cranes actually put energy back into the grid when lowering containers otherwise the energy would go to waste... Not saying it's not happening, just would like to know more supporting information about these dock side diesel generators? Quote Link to post Share on other sites
waikiore 501 Posted July 30, 2022 Author Share Posted July 30, 2022 She has two C32 Cats onboard to enable her to fulfill her demanding role , in fact they were out last night practicing Quote Link to post Share on other sites
El Toro 115 Posted August 7, 2022 Share Posted August 7, 2022 It motored down here from overseas under its own steam 1 Quote Link to post Share on other sites
waikiore 501 Posted August 8, 2022 Author Share Posted August 8, 2022 Yes Motored by lovely diesels 1 Quote Link to post Share on other sites
