timberwolf
What is really cool about the new boom is that the Top rail perfectly matches the reverse sheer of the new amas.
We are launching on Wednesday morning (without the rig in).
Most likely not ready to sail by Easter but have already entered the Winter series that starts on April 30th.
Two centrecase cages to house the CNC Machined Bearings. Also Carbon Instrument bracket and GPS and VHF aerial mounts.DSC07388.JPG
Wolfy likes his new home at Westhaven. He is very happy to be back in the water.
He motored briskly around from Okahu Bay, floating to his lines, and handled the Various wakes thrown at him with ease.
First Photo shows the Carbon Cage with the CNC'd plastic bearings installed. Many thanks to Russell of Absolute CNC for those !
Other two photos are of the Curved foil tips, glued on.
The Tips are to prevent an equalisation of pressure at the end of the curved foil.
The Tip of the curved foil is the closest to horizontal and is therefore providing the most lift, much of this lift is negated if the pressure escapes around the end.
The big disadvantage of these tips is that the foil needs to be installed from the underside, up, which can cause big issues if you are in very shallow water and you need to remove the foils to prevent the boat sitting on them.
Hi Tim - you have been busy! Interested in those big tips on the board - since they have to be taken out from the underside are the curved boards essentially permanent fixtures - i.e the tips will always be in the water? I would think that could be a major downer in the light. Below is a quote from "Bull" on the use of the banana boards on TVS - they seem to find they are better off without any curved board below 10 knots. What is the plan with those boards in the light conditions?
Quote Bull from Why hasn't someone part II thread - "This is an interesting discussion for sure, and without being any sort of expert by any means this is what we think we have learned at this stage after a season with curved boards.
In the light we use no Curved Ama Board (CAB) as we are better off minimising drag and just using Main Board (MB). The MB is 7m long and we draw about 4.2 when fully down. We will even reduce MB in the extra light.
One of the really interesting aspects of the CAB's, and these are asymetrical and can be adjusted for both horizontal and verticle angles of attack by chock changes, is that the first bit of board you put down is vertical, effectively producing horizontal lift and as you put down more the curve means it becomes horozontal, producing vertical lift.
We find bellow 10- 12 knots of air up hill we use no CAB and just MB, minimum drag. As pressure increases we start running CAB up to 60% max so mostly lateral loads not lifting. So up hill that is max.
As soon as the boat is over 20-22 knots of boat speed, so cracked or running in moderate or heavy, we use full CAB and she effectivly becoms a foiler with only the last 6-10ft of ama in the water and the foil taking 70-80%of the load. The difficult area is where its puffy like the harbour and you are on and off the gas and dont need full CAB all the time, its a bit of a compromise."
You are spot on Dean.
In the light we will pull the boards up, but leave a gap between the Tip and the hull of at least 50mm, i.e. 50mm of the Curved foil plus the tip is in the water at all times.
That is the same with G3, their tips are always in the water as well.
By way of perspective though, the Tips are only 6mm thick, and 100mm deep, so really there is very little drag there, at all.
Ah bummer... Although thats a pretty small mistake to make considering the other opportunities there were for them like putting the cases around the wrong way or something far worse!
tim - I wondered if it would be possible to 'bolt' these tips on by sinking threaded inserts into the ends. That way you'd be able to remove during a little swim so that you can fully extract the foil. I'm guessing you've already thought of this and discarded it for some reason that's gone way over my humble head.
They are glassed on, so they don't crack, they need a cove on the inside, and are heavily rounded on the outside to reduce drag.
Also bear in mind if the boat dries out, all the weight is on these tips.
