Romany 164 Posted September 17, 2023 Share Posted September 17, 2023 Has anybody used Durepox marine paints? I'm near to repainting newly glassed decks and cabin top - plus topsides repair ( full top sides next year) and at the decision point. Ive no idea cost comparisons/ application differences. At this stage just interested in suitability and mostly - durability Quote Link to post Share on other sites
Psyche 899 Posted September 17, 2023 Share Posted September 17, 2023 The benefit of Durepox is that it's a one coat system, its primer, undercoat and topcoat in one. You can add clear to white to get more gloss and UV protection. It wont have the gloss and long term colour retention of LPU systems though. Topsides should really be LPU, for the decks it all depends on how you want to do the non-skid. The best painted non skid is sprayed grit particles and that's done with LPU. Durepox is fine, but its not going to be a superyacht finish is the short answer but its tough and long lasting. Quote Link to post Share on other sites
Ex Machina 390 Posted September 17, 2023 Share Posted September 17, 2023 11 hours ago, Romany said: Has anybody used Durepox marine paints? I'm near to repainting newly glassed decks and cabin top - plus topsides repair ( full top sides next year) and at the decision point. Ive no idea cost comparisons/ application differences. At this stage just interested in suitability and mostly - durability Yep got it below the waterline on a trailer yacht . It’s apprently 12 years old and still looks like new . Also have it in black on the gennaker prod and on the rudder too . I didn’t apply it myself I have a clever mate that’s good at that sort of thing , he has a trick of mixing fairing compound into the primer coats so it works as a highbuild . 2 years out in the weather and the prod still looks like new . Quote Link to post Share on other sites
Romany 164 Posted September 17, 2023 Author Share Posted September 17, 2023 Thanks for replies. While I may think a Townson 36 is a super yacht, that may not be a widely shared view, however, tough and durable I like the sound of. What is an 'LPU' and why? On the subject of skid resistant finish I was going to go with kiwi grip I think its called. Quote Link to post Share on other sites
alibaba 85 Posted September 17, 2023 Share Posted September 17, 2023 Kiwi grip is really good - it's water based and easy to apply with the special roller. When I used it first I was a bit concerned about its durability because of the water base, but it's as hard as nails, and wears well, so don't make the finish too coarse, or you'll take the skin off 1 Quote Link to post Share on other sites
Black Panther 1,816 Posted September 17, 2023 Share Posted September 17, 2023 +1 for kiwigrip Quote Link to post Share on other sites
Romany 164 Posted September 22, 2023 Author Share Posted September 22, 2023 Thanks all. Guest - can we talk further? You have used it which is the experience I need to tap into. Please gis a bell on 0212408404 or text me a number and I'll call u. Cheers Quote Link to post Share on other sites
Cheap Transport 77 Posted September 23, 2023 Share Posted September 23, 2023 Used a lot of it last year during our 1020 refit. Key to no bubbles is getting your thinning ratios right for your chosen application, temperature and relative humidity. To get your UV stability, reduce long term chalking of the coating etc you should be adding 15-20% durepox high performance gloss into your white/ black/ whatever durepox colour you have (unless it's below the water line, then I'm not sure). In regards to what Guest said about the tape tearing the paint, it really depends on what tape type using. It surprises me how few people are using the more modern Washi tapes (rice paper tape), and continue to use crepe paper or vinyl tapes from the likes of 3M or Scotch or similar. There's good quality washi tapes available that have wax polymer coatings on them meaning the paint won't stick to it, while leaving razor sharp lines when you remove it. I've moved a few guys onto it down at our local club with a boat builder now buying it by the box full. It'll change your life🤣 1 Quote Link to post Share on other sites
Romany 164 Posted September 23, 2023 Author Share Posted September 23, 2023 Thanks for that - the comment from guest was related to kiwigrip although i suppose its applicable to any paint system and your reply about the tape is equally so. Quote Link to post Share on other sites
Vivaldi 62 Posted September 24, 2023 Share Posted September 24, 2023 6 hours ago, Cheap Transport said: Used a lot of it last year during our 1020 refit. Key to no bubbles is getting your thinning ratios right for your chosen application, temperature and relative humidity. To get your UV stability, reduce long term chalking of the coating etc you should be adding 15-20% durepox high performance gloss into your white/ black/ whatever durepox colour you have (unless it's below the water line, then I'm not sure). In regards to what Guest said about the tape tearing the paint, it really depends on what tape type using. It surprises me how few people are using the more modern Washi tapes (rice paper tape), and continue to use crepe paper or vinyl tapes from the likes of 3M or Scotch or similar. There's good quality washi tapes available that have wax polymer coatings on them meaning the paint won't stick to it, while leaving razor sharp lines when you remove it. I've moved a few guys onto it down at our local club with a boat builder now buying it by the box full. It'll change your life🤣 Where can you the Washi tapes from? Quote Link to post Share on other sites
raz88 98 Posted September 24, 2023 Share Posted September 24, 2023 https://tradedepot.co.nz/tdx-washi-painter-tape-purple/?gclid=Cj0KCQjwvL-oBhCxARIsAHkOiu29hGsOdNs09wNetlJgb2-f1Dr4PYWGUgQNvQvaSB2OrWB3j2hvasQaAnmvEALw_wcB Quote Link to post Share on other sites
Cheap Transport 77 Posted September 24, 2023 Share Posted September 24, 2023 6 hours ago, Vivaldi said: Where can you the Washi tapes from? Most decorative/architectural paint retailers carry it - Paint Plus, Dulux, Resene etc with Tapespec and Pomona making better quality tapes than most... in my opinion anyway. Quote Link to post Share on other sites
ex Elly 276 Posted September 25, 2023 Share Posted September 25, 2023 Mitre 10 https://www.mitre10.co.nz/shop/search?text=washi&q=washi Quote Link to post Share on other sites
Dodge Taxi 6 Posted September 30, 2023 Share Posted September 30, 2023 Another plus for Durapox is that the pack is a full 5 liters and hardener is available separately. I use it for almost everything. Sprays and rolls well. Quote Link to post Share on other sites
Rgvkiwi 15 Posted November 3, 2023 Share Posted November 3, 2023 Where do you guys source Durepox in Auckland? Quote Link to post Share on other sites
Cheap Transport 77 Posted November 3, 2023 Share Posted November 3, 2023 2 minutes ago, Rgvkiwi said: Where do you guys source Durepox in Auckland? You can source it directly from Resene in MtWellington or any automotive paint supplier can get it in. Wairau Paint Centre stocks it in black and white if you're on the Shore. Quote Link to post Share on other sites
Nathan1000 7 Posted November 3, 2023 Share Posted November 3, 2023 We used Durepox last year on the deck. Main reason I chose Durepox was I could get it colour matched to our paint colour. Was easy to use and has a very hard finish. I liked it. Also stripped and painted aluminium hatch covers and used on them, no primer needed. For non stick we sprinkled intergrip which worked fine. Tried mixing it in but didnt give the same grip as sprinkling it out a large salt shaker. I would recommend. Quote Link to post Share on other sites
