Oracle1 21 Posted October 16, 2014 Share Posted October 16, 2014 before and after pic's ? Quote Link to post Share on other sites
Changed 10 Posted October 16, 2014 Share Posted October 16, 2014 Will do. Quote Link to post Share on other sites
Island Time 1,360 Posted October 19, 2014 Share Posted October 19, 2014 Well, its not really only this weekend, but I'm redoing the interior finishes on Island Time. Mostly the varnish work, including the 9 louvered doors! Man louvers are a pain to re-do, it takes about a day to sand them back to the timber... but they do allow air flow, and work well in the boat. I took out the oven this weekend, sanded and undercoated the oven space as well, using perfection undercoat. I using Bondall Clear marine varnish, marine grade, single pot, from Mitre 10 - thanks Wheels for telling me about that! It's coming up pretty well. I have been surprised though by the color change from the old varnish (probably original, 1988) on the mahogany interior. I guess the old stuff had bleached, as the new is darker, but shows the grain better and looks deeper. Most is being done with satin, but some parts (fiddles, handholds etc) in gloss. I'm about 30% of the way through the main saloon so far, so it will be a few months before it's all done, and we are still sailing during the process. Quote Link to post Share on other sites
Changed 10 Posted October 19, 2014 Share Posted October 19, 2014 Got all of the glassing completed this weekend so now just the exterior paint and we're back in business. Quote Link to post Share on other sites
Atom Ant 0 Posted October 21, 2014 Share Posted October 21, 2014 Bloody good job Richard, Much more usable cockpit now. Quote Link to post Share on other sites
Changed 10 Posted October 21, 2014 Share Posted October 21, 2014 Yeah I'm happy has cost me less than a grand and to date about seventy hours. Still needs final sand and paint though. Seems a shame to clutter the space with a traveller now. Quote Link to post Share on other sites
Changed 10 Posted November 2, 2014 Share Posted November 2, 2014 Faired and undercoated. Finish coats next weekend and non-skid then bolt everything back. Quote Link to post Share on other sites
Island Time 1,360 Posted November 10, 2014 Share Posted November 10, 2014 Well, I was going to go out for the weekend. Went down to the boat to discover a whole 4.5KG LPG bottle had emptied in the last week! The gas alarm in the boat was not triggered (while I was there anyway) and there was no gas smell in the bilge. But obviously there was a leak! How I located and repaired the leak- maybe this will be useful for someone else; As we have a LPG califont for the water heater, the gas is not normally turned off at the bottle, so the hot water works. I had to find the leak. It's a bit complex on Island Time, as there are 4 gas lines in the boat from the same supply, One to the oven, one to the heating, one to the BBQ, and one to the califont. The lines are mostly original copper, now about 25 years old, with some flexible rubber as well. I started with the basic pump/squirt bottle with dish liquid and water. I connected a full gas bottle, and went over all the connections, the bottle and the reg etc - could not find anything. LPG/Propane is pretty low pressure (on the low pressure side) only about 1psi. So I decided I could use AIR at a bit more pressure to check again, with more safety and more likelihood of finding the issue. What I did was to remove the hose from the regulator to the boat piping, and replace it with a short piece of gas hose. Clamped that on to the boat pipes, and in the free end I fitted a truck's removable tire valve. I then fitted a pressure gauge (That I had lying around in the garage, but a tire pressure gauge would do >$10 at Supercheap) to the first T joint on the boat (removed the BBQ connection). This would allow me to monitor the pressures to see when I'd fixed the leak. Using a bicycle pump, I pumped up the pressure to 10psi. There certainly was a leak - you could watch the pressure drop over about 30 seconds down to less than 1psi. So, firstly the leak was not in the BBQ line, as it was no longer connected. 3 of the 4 branches to go! Disconnecting them one at a time and re-testing ascertained the leak was in the pipe to the oven. I then disconnected the flexible lead to the gimballed oven and blocked that off to see if the leak was in the copper pipe, or the flexible part or oven. It was (murphys law) in the copper. That was installed when the boat was built - and it was behind the built in cabinets etc. Bugger. The copper's conduit was too small for a flexible hose replacement. It also had a sharp (90 deg) bend in it where it exited one conduit and went into the final one feeding to to the back of the stove. That section I could see thru the back of one of the cabinets, but it could not be reached - impossible to replace without removing major built in cabinets. So, replacing the copper not realistically practical. I spent the day replacing the copper behind the cabinets with flexible gas line, running a different route, all well supported, and exiting through the same final conduit (which was large enough) behind the oven. Crimped the end connections (worm drive hose clamps are not allowed!) - a hint - you can crimp the connections with carpenters pliers if you don't have the special crimpers. Once done, retested with the 10psi pressure test. No change at all after 30mins - Fixed! Remove the test stuff, re-install the gas bottle and reg, test all connections again with the soapy water. All good! Total cost $60 for the new line and the right crimp connections, + 2 replacement connectors to change from the copper flares to a bayonet for the hose. In all, it took about 8-9 hours, so would have been expensive to have it done by a tradie. Went sailing on Sunday... Quote Link to post Share on other sites
smithy09 50 Posted November 10, 2014 Share Posted November 10, 2014 Nice job IT. Logical approach.... Quote Link to post Share on other sites
Changed 10 Posted November 11, 2014 Share Posted November 11, 2014 There is no doubt that a 'do-it-youselfer' can save a lot. Quote Link to post Share on other sites
Guest Posted November 12, 2014 Share Posted November 12, 2014 Richard is so right regarding the projects one can successfully tackle and complete to a high standard. Been watching him rip apart and alter his pride and joy and it is a remarkable transformation done to a great standard. Well done that man in the protective suit and mask. Quote Link to post Share on other sites
DrWatson 382 Posted November 12, 2014 Share Posted November 12, 2014 My 3 extra hours per day are starting to pay off... Quote Link to post Share on other sites
Changed 10 Posted November 13, 2014 Share Posted November 13, 2014 Good video about building in a confined space. Quote Link to post Share on other sites
JK 28 Posted November 13, 2014 Share Posted November 13, 2014 You figured out how to get it outside when finished? Quote Link to post Share on other sites
DrWatson 382 Posted November 13, 2014 Share Posted November 13, 2014 You figured out how to get it outside when finished? The solution to that equation will be determined in due course...lol Quote Link to post Share on other sites
Changed 10 Posted November 16, 2014 Share Posted November 16, 2014 Back at it this weekend. One more coat of non-skid, fit the traveller and fine trim and we're ready. Shame I'll miss the Yates Cup. Quote Link to post Share on other sites
courageous 0 Posted November 16, 2014 Share Posted November 16, 2014 Gave a mate a hand to put the finishing touches on the bottom of his cat at Little Shoal Bay.What A great cross section of folks and boats, It's probably one of the last classic kiwi hardstands where there's always time for a chat and a cold one ... Cheers Courageous Quote Link to post Share on other sites
Guest Posted November 16, 2014 Share Posted November 16, 2014 Laminated up a cockpit floor / roof for nuclear bomb shelter. I don't want to have to be light of foot. Quote Link to post Share on other sites
DrWatson 382 Posted November 16, 2014 Share Posted November 16, 2014 Had dinner aboard. Quote Link to post Share on other sites
Black Panther 1,849 Posted November 17, 2014 Share Posted November 17, 2014 Quote Link to post Share on other sites
