This Weekend's Achievements
1697 replies to this topic
#1641 Black Panther
Black Panther
  • Administrators
  • 5,828 posts
Posted 18 August 2019 - 08:47 PM
Nice work rigger!
  Two figures sat side by side, staring at the Sea. One said to the other, “You know that one day we will die.” And the other friend replied, “But all of the other days WE WILL LIVE!”
#1642 rigger
rigger
  • 3,521 posts
Posted 18 August 2019 - 08:50 PM
Thanks BP,
Also working on one half the diameter.
#1643 Fish
Fish
  • 3,557 posts
Posted 19 August 2019 - 09:02 AM
I successfully managed to change a head light bulb in a late model European car.
Anyone wondering why this is worthy of positing as a weekend's achievement clearly hasn't had the pleasure of completing such an apparently simple task. Damn near physically impossible. A sense of achievement equivalent to sailing around the country with only one mate.
European cars are clearly not designed for european male hands. And why do they have layer upon layer of apparently pointless plastic covers, screens and shrouds? All they do is give the impression the engine is too complex to touch, and hide the bit you are actually trying to find.
Bring back my old HJ Holden. I could unbolt the bonnet and stand beside the engine with one leg either side of the front suspension, and change the head gasket in an afternoon. Could even change the whole engine in a weekend, and consequently carry the old one around in the boot for spare parts... didn't even need a computer to tell me what the engine fault was!
#1644 SloopJohnB
SloopJohnB
  • 6,533 posts
  • LocationPatumahoe
Posted 19 August 2019 - 09:05 AM
Attached File  Capture.JPG   55.58KB   0 downloads
  • 5
"With age comes wisdom .... and with wisdom comes the knowing when to avoid perfection!"
#1645 Ed
Ed
  • 564 posts
Posted 19 August 2019 - 10:17 AM
Not racing but still a nice sail a the weekend
http://youtu.be/fAROoHPwTnY
  • 1
#1646 DrWatson
DrWatson
  • 2,259 posts
  • LocationLand locked
Posted 21 August 2019 - 08:25 PM
OK, so it took a few extra days to get any photos.
Here's the "big" day, when the Zürich Water Police surveyed the boat and made their assessment as to its seaworthiness. Using a crude formula they determined the number of people it's allowed to have on board when sailing (anyone care to guess?) - formula uses only beam and length (1.42 x 3.85m). We're now registered and allowed to use the boat, but I have to make a builder's plate with hull number etc... (lol).
By my calculations using straight line interpolation between the sections, it will take 475kg to reduce freeboard to 25cm, and there's 142L of sealed tankage under the main cockpit seats.
We stepped the mast and they actually tipped it right over until it flooded. But it sat very high, taking on probably less than 150L of water when they allowed it to right. All of that was in the forward section between the centreboard and the forward thwart.
Only in Switzerland does one use a crane to launch a 65kg boat...
  • 1
#1647 Tazzy Devil
Tazzy Devil
  • 167 posts
Posted 15 September 2019 - 05:52 PM
Did this to my boat today...
  • 1
#1648 BOIGuy
BOIGuy
  • 109 posts
Posted 16 September 2019 - 07:34 AM
Making room for the new foils
#1649 Island Time
Island Time
  • Administrators
  • 7,082 posts
Posted 16 September 2019 - 08:24 AM
Cool, who designed the new one? Whole keel or just bulb?
#1650 Tazzy Devil
Tazzy Devil
  • 167 posts
Posted 16 September 2019 - 08:57 AM
Nothing as exciting as that...
I bought the boat about a year ago straight after a so called boatbuilder had redone the keel (and charged the previous owners quite a bit of money to replace keelbolts etc).
Turns out they had no clue about what they were doing (look out aucklanders if you are getting keel work done)
Keel was faired pretty similar to what a 2 year old might make out Plasticine, warped and hollowed out with a trailing edge curved off to port (probably why we were 4 degrees better on one tack and the boat rounded up at random occassionally.
So the plan was to refair the keel but once sanded back we noticed the dreaded red weeping. Turns out the trailing edge had been sanded through (probably trying to get it remotely fair) and then water had seeped in and run along the base plate.
Fortunately the deadwood is solid cedar not ply and there was a filler "Dam" so the water didn't seep up any higher. given saltwater in oxygen free environment are not a great idea we took out the section and now the pros are involved fixing it. Guessing shape some high density foam or wood then glass it in.
Pretty gutting but very pleased I found it now!
Interestingly there is a cavity with a whole bunch of lead shavings and some balck tar type stuff in it. Only around 5kg of shavings but random to find.
