Deep Purple 512 Posted January 25, 2021 Share Posted January 25, 2021 A little over a day before the biggest keelboat regatta in the country kicks off and we have no safety regulations. Quote Link to post Share on other sites
ex Elly 197 Posted January 25, 2021 Share Posted January 25, 2021 You will have a very light boat, since you can now remove all the safety gear! 1 1 Quote Link to post Share on other sites
splat 55 Posted January 26, 2021 Share Posted January 26, 2021 what regulations?.... 1 Quote Link to post Share on other sites
Cantab 341 Posted March 19, 2021 Share Posted March 19, 2021 I see the new regs are up again. Still don't address the fundamental conflicts between OSR and the NZ regs. Still a draft by the looks of it. There are enough representatives at WS from NZ to get this done properly. Not quite a pass mark yet. Quote Link to post Share on other sites
Deep Purple 512 Posted March 19, 2021 Share Posted March 19, 2021 Yep I had a preview a few weeks back and pointed out a typo that appears to have been fixed the 50% reef is gone nav lights must now be wired into the central electrical system my main concern is that the NZTYA still controls trailer yacht regulations and nothing there has changed. Neither has there been consistency created between trailer yachts and keelboats here are the changes Summary of changes to Safety Regulations for 2021 - 2024 This is an extensive summary of the changes to be made to the 2021-24 Yachting New Zealand Safety Regulations of Sailing (SRS) Where possible it is highlighted what the change being made is from and to. In section discussing Part III – comparison of changes will need to be made from the 2017-2020 Safety Regulations (SRS) booklet or online version found here: https://www.yachtingnz.org.nz/resources/yachting-new- zealand-safety-regulations-sailing-2017-2020 Introduction Pg. 6 Change from: New Zealand-flagged ships departing New Zealand require an inspection certificate to complete New Zealand Customs documentation requirements prior to departure. For more information, please see Part III of these regulations. To: New Zealand-flagged ships departing New Zealand require a Yachting New Zealand category 1 Safety Certificate to complete New Zealand Customs documentation requirements prior to departure. For more information, please see Part III of these regulations. Part II Offshore & Coastal Racing & Cruising 3.0 SAFETY INSPECTORS Change from: Inspections undertaken by Yachting New Zealand Yacht Inspectors are not surveys of the general condition of the vessel. Inspections are made visually and are for the purpose of verifying whether a vessel, its equipment and crew are safe to undertake a voyage or enter races organised by Yachting New Zealand-affiliated clubs. The inspection certificate may not be used for any other purpose by any person. NOTE: Inspectors may use their discretion as to the acceptability of items not listed. Change to: Inspections undertaken by Yachting New Zealand Yacht Inspectors are not surveys of the general condition of the vessel. Inspections undertaken by Yachting New Zealand Yacht Inspectors are made visually and are for the purpose of verifying whether a vessel, its equipment and crew are suitable to undertake the voyage. The Safety Certificate may not be used for any other purpose by any person. NOTE: Yacht Inspectors may use their discretion as to the acceptability of items not listed. 3.10 Change from: Skippers of vessels over 20m and vessels that have been in MOSS (Maritime Operator Safety System) requiring a Category 1 certificate for customs clearance should contact a yacht safety inspector who must consult with Maritime New Zealand. Change to: Skippers of vessels that require a Category 1 certificate that: a) have been in MOSS (Maritime Operator Safety System) and/or b) are complex, and/or is of a size where certain International convention requirements may apply (generally >24m or >400GT) i.e. SOLAS, MARPOL, COLREG, MLC, etc. are to consult with a Yacht Inspector prior to inspection there may be a requirement for Maritime NZ assistance with vessel inspection. 4.04 Category 3 Remove: and not rounding major capes Reason: Alignment with the World Sailing definition. 13.0 FLOODING PREVENTION, HATCHES, WINDOWS, BILGE PUMPS, STORM COVERINGS 13.10 (M) On all multihulls a readily usable safe method of entering and exiting from the inverted vessel must be provided to allow a fully clothed person to pass through this entry/exit which must be clear of the water at all times, upright or inverted. It is required that skylights and hatches must be fastened from below to allow exit in case of emergency. If this is not possible a cutting line shall be clearly marked - Escape Cut Here, and appropriate hull cutting tools kept secured nearby for instant use adjacent to the intended cutting site. Add: If hatches are used for this purpose, a storm board must be carried that can be used to rapidly over the hatch should it fail. 13.11 (K) Change from: Storm coverings are required for all windows more than 1852 cm2 (2sqft) in area Change to: Storm coverings shall be fitted for all windows more than 1858 cm2 in area 13.12 (M) Change from: Storm coverings for exposed windows more than 1852cm2 (2sqft) in area shall be provided or it shall be demonstrated that the window material as installed will withstand severe blows and remain intact. In the case of curved glass windows, properly positioned and secured, very heavy covering material, may (as the only practical solution) be permitted as a substitute storm shutter. Change to: Storm coverings for exposed windows more than 1858cm2 in area shall be fitted. 13.14 Change from: At least two manually operated bilge shall be securely fitted to the yacht’s structure, one operable above, the other below deck. Each pump shall be operable with all cockpit seats, hatches and companionways shut. Alternatively, one bilge pump may be of a portable nature provided that it can be adequately secured to the yacht’s structure. a. One manual bilge pump operable with all cockpit seats, hatches and companionways closed. b. One manual bilge pump. Add: 13.14 (M) Two manual Bilge Pumps, either fixed or portable. Reason: Most multihulls only carry portable manual bilge pumps as the layout of the hulls and watertight tight compartments generally mean fixed bilge pumps are useless. 16.0 ACCOMMODATION 16.05 (M) Permanently installed bunks shall be provided for a minimum of the nearest whole number greater than 2/3 of the crew. Each bunk shall be a minimum of 45cm x 1.8m and shall have a resilient mattress that dries easily. In every case there shall be a minimum of two bunks. Remove: The requirement for a mattress on bunks. 16.13 Remove: the requirement for a water tank for category 3, 4 & 5. Reason: Race boats carried bottle water. Changed to: At least one securely installed water tank. 17.0 SAFETY SYSTEMS AND EQUIPMENT 17.13 (C) The Dan Buoy pole shall be either permanently extended or an approved folding or inflatable pole attached to the ring by a suitable floating line, the coloured flag must fly at least 2.5m (8 ft) off the water. MNZ round 76 cm (30 in) lifebuoys or horseshoe lifebuoys are acceptable. Change to: Flag height to be 2 metres in line with international regulations. 17.17 Lifelines – minimum diameter lifeline wire shall be: Add X X for category 4 & 5 18.0 COMMUNICATIONS 18.02 Handheld VHF radio Change to: all vessels required to have on board all categories. 18.03 Remove: Radio receiver capable of receiving weather bulletins 18.07 Change from: Flares must not be more than 3 years old as indicated by the expiry date... Change to: Flares on the vessel must be within the expiry date at all times. 19.03 (e) Charts publications and plotting systems Add: recommended for category 4 & 5 19.0 NAVIGATION 19.04 (d) Add: (e) Echo (Depth) Sounder or lead line category for category 4 & 5 19.07 Navigation Lights Add: and wired into the vessels electrical system. Part III Pleasure yachts departing New Zealand for overseas Change to: Section 21 of the Maritime Transport Act 1994 (the MTA) requires masters of pleasure craft departing from any port in New Zealand for overseas to notify the Director of Maritime New Zealand (the Director, Maritime NZ) of their proposed voyage. The Director must be satisfied that the pleasure craft and its safety equipment and crew are adequate for the proposed voyage. A certificate of clearance from Customs is also a pre-requisite for departure under section 21. The Director has delegated this statutory power to Yachting New Zealand. Sub-delegation from Yachting New Zealand to Yacht Inspectors mean that the Yacht Inspectors carry out these inspections to Category 1 standards. REQUIREMENTS BEFORE DEPARTING NEW ZEALAND FOR ANY PLACE OUTSIDE NEW ZEALAND (1) All vessels must hold a registration under a flag state. New Zealand ships register with the Registrar of Ships Maritime New Zealand (2) Yachting New Zealand Safety Inspection certificate and the Maritime New Zealand 12409 certificate. (3) Notify the Director of Maritime New Zealand by completing an intention to depart notification form (4) Completed New Zealand Customs requirements. Refer to the New Zealand Customs website. www.customs.govt.nz 1.0 SHIP REGISTRATION All vessels travelling internationally must be registered in a flag state such as with the Registrar of Ships, Maritime New Zealand www.maritimenz.govt.nz Please note: Registration as a New Zealand ship is not the same as a Yachting New Zealand registration which is required for all vessels wishing to race in New Zealand. For more information contact Yachting New Zealand or see www.yachtingnz.org.nz Registration as a New Zealand ship can be done either under Part A or Part B. Both provide a ship with New Zealand nationality and protects a ship’s name for as long as it is registered. Note: New Zealand-registered vessels are required to fly either the New Zealand state flag or the New Zealand red ensign while in the territorial waters of foreign countries. 2.0 SAFETY INSPECTIONS Under Section 21 of the Maritime Transport Act 1994, a New Zealand registered pleasure craft may not leave any port in New Zealand for any place outside New Zealand unless the Director of Maritime New Zealand is satisfied that: · the vessel and its safety equipment are adequate for the voyage; and · the vessel is adequately crewed for the voyage; and · the master observes any other relevant maritime rules. All New Zealand vessels must undergo a safety inspection prior to departure to obtain a Category 1 safety certificate. The inspection will focus on: · the design and construction of the boat being suitable for the voyage and meeting the required standards · the safety and communication equipment meeting specific requirements and all safety equipment being in date · the skipper and crews ability to undertake the proposed voyage safety and demonstrate preparedness for emergency situations. The decision on whether to grant section 21 clearance is made by the Director, or their delegate (i.e. a Yachting New Zealand Yacht Inspector). In determining the adequacy of the vessel, the Yacht Inspector shall have regards to any previous offshore voyages undertaken by that vessel and will use the Category 1 requirements set out in part II of these regulations except in exceptional circumstances. There may well be occasions where there are justifiable grounds for not following these Safety Regulations, but these must be carefully considered and well recorded by the Yacht Inspector and Yachting New Zealand. A Category 1 inspection certificate is valid for one clearance only and expires at first port of call, and then reverts to a Category II for two years. Yachting New Zealand Safety Certificates are valid from the day they are signed, for a period of 60 days from the signed date on the certificate to allow adequate time for the vessel to leave. Skippers can apply for a 30 day extension directly to the Yachting New Zealand Safety and Technical Officer stating the reasons for requesting an extension, provided there are no changes to the vessel, its equipment or crew as originally inspected. Beyond this timeframe, the Yachting New Zealand Safety Certificate is considered expired (invalid). During this 60 (or 90) day period, the Yachting New Zealand Safety Certificate remains valid, providing: · There are no crew changes; · The safety equipment on board remains in date until the estimated destination arrival date; · No significant alternations to the vessel have been made (including the hull, rig or equipment); or · No damage has occurred to the yacht (i.e. as a result of grounding). The following could be reasons for needing re-issue of the certificate: · Notification to Yacht Inspector only: - Crew change · Supply of photo(s) or other evidence to Yacht Inspector: - safety equipment change (out of date refreshing), minor equipment change · Re-inspection required: - major equipment change or alteration to the yacht, or skipper change, or extending the certificate validity beyond 90 days For information on contacting a Yacht Inspector and getting your boat inspected, please see the introduction to these regulations or the Yachting New Zealand website www.yachtingnz.org.nz 3.0 NOTIFICATION OF DIRECTOR All masters must notify Maritime NZ of their intended departure. Go to www.maritimenz.govt.nz to complete an intention to depart notification form. 4.0 CUSTOMS NEW ZEALAND You must leave NZ waters from an authorised port of departure. Customs request the completed departure forms three days before departure to help avoid processing delays. www.customs.govt.nz Part VII Sport Multihull Yachts Sport Multihull Equipment: Helmet – each crew member to wear a suitable water sports helmet. Add: In light conditions with the skipper’s express permission these may be removed but must be carried on the vessel at all times. Support Boat Requirements from Sport Multihull Equipment: Add: Bosuns Chair or suitable climbing harness (Lirakis) – each vessel to have at least one bosons chair or suitable climbing harness. Tools – suitable tools for the individual vessel requirements. Appendix 1 Medical Stores Add ‘At least two crew members’ shall have a current first aid certificate Part V Trailer Yachts & Sports Trailer Yachts 9.11 First Aid Add For details of a complete first aid kit, refer to the Safety Regulations of Sailing Appendix 1 Quote Link to post Share on other sites
Deep Purple 512 Posted March 19, 2021 Share Posted March 19, 2021 PDF version SRS Summary of Changes 3 March 2021_v2.pdf 1 Quote Link to post Share on other sites
Start Me Up 4 Posted March 20, 2021 Share Posted March 20, 2021 Thanks for that DP. I will now work on making the Weaver Dan buoy marginally shorter. The couriers might charge me less! No consultation with me as the sole manufacturer to the change. Also no consultation or publicity to the chandler's that YNZ were re releasing the rules. Likely its been very good that we're here in our bubble not allowed to go anywhere to save any confusion with industry/regulator/end user. 1 Quote Link to post Share on other sites
splat 55 Posted March 21, 2021 Share Posted March 21, 2021 On 20/03/2021 at 9:23 AM, Deep Purple said: Yep I had a preview a few weeks back and pointed out a typo that appears to have been fixed the 50% reef is gone nav lights must now be wired into the central electrical system my main concern is that the NZTYA still controls trailer yacht regulations and nothing there has changed. Neither has there been consistency created between trailer yachts and keelboats here are the changes Summary of changes to Safety Regulations for 2021 - 2024 This is an extensive summary of the changes to be made to the 2021-24 Yachting New Zealand Safety Regulations of Sailing (SRS) Where possible it is highlighted what the change being made is from and to. In section discussing Part III – comparison of changes will need to be made from the 2017-2020 Safety Regulations (SRS) booklet or online version found here: https://www.yachtingnz.org.nz/resources/yachting-new- zealand-safety-regulations-sailing-2017-2020 Introduction Pg. 6 Change from: New Zealand-flagged ships departing New Zealand require an inspection certificate to complete New Zealand Customs documentation requirements prior to departure. For more information, please see Part III of these regulations. To: New Zealand-flagged ships departing New Zealand require a Yachting New Zealand category 1 Safety Certificate to complete New Zealand Customs documentation requirements prior to departure. For more information, please see Part III of these regulations. Part II Offshore & Coastal Racing & Cruising 3.0 SAFETY INSPECTORS Change from: Inspections undertaken by Yachting New Zealand Yacht Inspectors are not surveys of the general condition of the vessel. Inspections are made visually and are for the purpose of verifying whether a vessel, its equipment and crew are safe to undertake a voyage or enter races organised by Yachting New Zealand-affiliated clubs. The inspection certificate may not be used for any other purpose by any person. NOTE: Inspectors may use their discretion as to the acceptability of items not listed. Change to: Inspections undertaken by Yachting New Zealand Yacht Inspectors are not surveys of the general condition of the vessel. Inspections undertaken by Yachting New Zealand Yacht Inspectors are made visually and are for the purpose of verifying whether a vessel, its equipment and crew are suitable to undertake the voyage. The Safety Certificate may not be used for any other purpose by any person. NOTE: Yacht Inspectors may use their discretion as to the acceptability of items not listed. 3.10 Change from: Skippers of vessels over 20m and vessels that have been in MOSS (Maritime Operator Safety System) requiring a Category 1 certificate for customs clearance should contact a yacht safety inspector who must consult with Maritime New Zealand. Change to: Skippers of vessels that require a Category 1 certificate that: a) have been in MOSS (Maritime Operator Safety System) and/or b) are complex, and/or is of a size where certain International convention requirements may apply (generally >24m or >400GT) i.e. SOLAS, MARPOL, COLREG, MLC, etc. are to consult with a Yacht Inspector prior to inspection there may be a requirement for Maritime NZ assistance with vessel inspection. 4.04 Category 3 Remove: and not rounding major capes Reason: Alignment with the World Sailing definition. 13.0 FLOODING PREVENTION, HATCHES, WINDOWS, BILGE PUMPS, STORM COVERINGS 13.10 (M) On all multihulls a readily usable safe method of entering and exiting from the inverted vessel must be provided to allow a fully clothed person to pass through this entry/exit which must be clear of the water at all times, upright or inverted. It is required that skylights and hatches must be fastened from below to allow exit in case of emergency. If this is not possible a cutting line shall be clearly marked - Escape Cut Here, and appropriate hull cutting tools kept secured nearby for instant use adjacent to the intended cutting site. Add: If hatches are used for this purpose, a storm board must be carried that can be used to rapidly over the hatch should it fail. 13.11 (K) Change from: Storm coverings are required for all windows more than 1852 cm2 (2sqft) in area Change to: Storm coverings shall be fitted for all windows more than 1858 cm2 in area 13.12 (M) Change from: Storm coverings for exposed windows more than 1852cm2 (2sqft) in area shall be provided or it shall be demonstrated that the window material as installed will withstand severe blows and remain intact. In the case of curved glass windows, properly positioned and secured, very heavy covering material, may (as the only practical solution) be permitted as a substitute storm shutter. Change to: Storm coverings for exposed windows more than 1858cm2 in area shall be fitted. 13.14 Change from: At least two manually operated bilge shall be securely fitted to the yacht’s structure, one operable above, the other below deck. Each pump shall be operable with all cockpit seats, hatches and companionways shut. Alternatively, one bilge pump may be of a portable nature provided that it can be adequately secured to the yacht’s structure. a. One manual bilge pump operable with all cockpit seats, hatches and companionways closed. b. One manual bilge pump. Add: 13.14 (M) Two manual Bilge Pumps, either fixed or portable. Reason: Most multihulls only carry portable manual bilge pumps as the layout of the hulls and watertight tight compartments generally mean fixed bilge pumps are useless. 16.0 ACCOMMODATION 16.05 (M) Permanently installed bunks shall be provided for a minimum of the nearest whole number greater than 2/3 of the crew. Each bunk shall be a minimum of 45cm x 1.8m and shall have a resilient mattress that dries easily. In every case there shall be a minimum of two bunks. Remove: The requirement for a mattress on bunks. 16.13 Remove: the requirement for a water tank for category 3, 4 & 5. Reason: Race boats carried bottle water. Changed to: At least one securely installed water tank. 17.0 SAFETY SYSTEMS AND EQUIPMENT 17.13 (C) The Dan Buoy pole shall be either permanently extended or an approved folding or inflatable pole attached to the ring by a suitable floating line, the coloured flag must fly at least 2.5m (8 ft) off the water. MNZ round 76 cm (30 in) lifebuoys or horseshoe lifebuoys are acceptable. Change to: Flag height to be 2 metres in line with international regulations. 17.17 Lifelines – minimum diameter lifeline wire shall be: Add X X for category 4 & 5 18.0 COMMUNICATIONS 18.02 Handheld VHF radio Change to: all vessels required to have on board all categories. 18.03 Remove: Radio receiver capable of receiving weather bulletins 18.07 Change from: Flares must not be more than 3 years old as indicated by the expiry date... Change to: Flares on the vessel must be within the expiry date at all times. 19.03 (e) Charts publications and plotting systems Add: recommended for category 4 & 5 19.0 NAVIGATION 19.04 (d) Add: (e) Echo (Depth) Sounder or lead line category for category 4 & 5 19.07 Navigation Lights Add: and wired into the vessels electrical system. Part III Pleasure yachts departing New Zealand for overseas Change to: Section 21 of the Maritime Transport Act 1994 (the MTA) requires masters of pleasure craft departing from any port in New Zealand for overseas to notify the Director of Maritime New Zealand (the Director, Maritime NZ) of their proposed voyage. The Director must be satisfied that the pleasure craft and its safety equipment and crew are adequate for the proposed voyage. A certificate of clearance from Customs is also a pre-requisite for departure under section 21. The Director has delegated this statutory power to Yachting New Zealand. Sub-delegation from Yachting New Zealand to Yacht Inspectors mean that the Yacht Inspectors carry out these inspections to Category 1 standards. REQUIREMENTS BEFORE DEPARTING NEW ZEALAND FOR ANY PLACE OUTSIDE NEW ZEALAND (1) All vessels must hold a registration under a flag state. New Zealand ships register with the Registrar of Ships Maritime New Zealand (2) Yachting New Zealand Safety Inspection certificate and the Maritime New Zealand 12409 certificate. (3) Notify the Director of Maritime New Zealand by completing an intention to depart notification form (4) Completed New Zealand Customs requirements. Refer to the New Zealand Customs website. www.customs.govt.nz 1.0 SHIP REGISTRATION All vessels travelling internationally must be registered in a flag state such as with the Registrar of Ships, Maritime New Zealand www.maritimenz.govt.nz Please note: Registration as a New Zealand ship is not the same as a Yachting New Zealand registration which is required for all vessels wishing to race in New Zealand. For more information contact Yachting New Zealand or see www.yachtingnz.org.nz Registration as a New Zealand ship can be done either under Part A or Part B. Both provide a ship with New Zealand nationality and protects a ship’s name for as long as it is registered. Note: New Zealand-registered vessels are required to fly either the New Zealand state flag or the New Zealand red ensign while in the territorial waters of foreign countries. 2.0 SAFETY INSPECTIONS Under Section 21 of the Maritime Transport Act 1994, a New Zealand registered pleasure craft may not leave any port in New Zealand for any place outside New Zealand unless the Director of Maritime New Zealand is satisfied that: · the vessel and its safety equipment are adequate for the voyage; and · the vessel is adequately crewed for the voyage; and · the master observes any other relevant maritime rules. All New Zealand vessels must undergo a safety inspection prior to departure to obtain a Category 1 safety certificate. The inspection will focus on: · the design and construction of the boat being suitable for the voyage and meeting the required standards · the safety and communication equipment meeting specific requirements and all safety equipment being in date · the skipper and crews ability to undertake the proposed voyage safety and demonstrate preparedness for emergency situations. The decision on whether to grant section 21 clearance is made by the Director, or their delegate (i.e. a Yachting New Zealand Yacht Inspector). In determining the adequacy of the vessel, the Yacht Inspector shall have regards to any previous offshore voyages undertaken by that vessel and will use the Category 1 requirements set out in part II of these regulations except in exceptional circumstances. There may well be occasions where there are justifiable grounds for not following these Safety Regulations, but these must be carefully considered and well recorded by the Yacht Inspector and Yachting New Zealand. A Category 1 inspection certificate is valid for one clearance only and expires at first port of call, and then reverts to a Category II for two years. Yachting New Zealand Safety Certificates are valid from the day they are signed, for a period of 60 days from the signed date on the certificate to allow adequate time for the vessel to leave. Skippers can apply for a 30 day extension directly to the Yachting New Zealand Safety and Technical Officer stating the reasons for requesting an extension, provided there are no changes to the vessel, its equipment or crew as originally inspected. Beyond this timeframe, the Yachting New Zealand Safety Certificate is considered expired (invalid). During this 60 (or 90) day period, the Yachting New Zealand Safety Certificate remains valid, providing: · There are no crew changes; · The safety equipment on board remains in date until the estimated destination arrival date; · No significant alternations to the vessel have been made (including the hull, rig or equipment); or · No damage has occurred to the yacht (i.e. as a result of grounding). The following could be reasons for needing re-issue of the certificate: · Notification to Yacht Inspector only: - Crew change · Supply of photo(s) or other evidence to Yacht Inspector: - safety equipment change (out of date refreshing), minor equipment change · Re-inspection required: - major equipment change or alteration to the yacht, or skipper change, or extending the certificate validity beyond 90 days For information on contacting a Yacht Inspector and getting your boat inspected, please see the introduction to these regulations or the Yachting New Zealand website www.yachtingnz.org.nz 3.0 NOTIFICATION OF DIRECTOR All masters must notify Maritime NZ of their intended departure. Go to www.maritimenz.govt.nz to complete an intention to depart notification form. 4.0 CUSTOMS NEW ZEALAND You must leave NZ waters from an authorised port of departure. Customs request the completed departure forms three days before departure to help avoid processing delays. www.customs.govt.nz Part VII Sport Multihull Yachts Sport Multihull Equipment: Helmet – each crew member to wear a suitable water sports helmet. Add: In light conditions with the skipper’s express permission these may be removed but must be carried on the vessel at all times. Support Boat Requirements from Sport Multihull Equipment: Add: Bosuns Chair or suitable climbing harness (Lirakis) – each vessel to have at least one bosons chair or suitable climbing harness. Tools – suitable tools for the individual vessel requirements. Appendix 1 Medical Stores Add ‘At least two crew members’ shall have a current first aid certificate Part V Trailer Yachts & Sports Trailer Yachts 9.11 First Aid Add For details of a complete first aid kit, refer to the Safety Regulations of Sailing Appendix 1 I see in 3.06 Cat 2 and 3 are now every 2 years. I thought Cat 2 was every three years? Quote Link to post Share on other sites
CarpeDiem 436 Posted March 21, 2021 Share Posted March 21, 2021 5 hours ago, splat said: I see in 3.06 Cat 2 and 3 are now every 2 years. I thought Cat 2 was every three years? Cat 3 has always been every 2 years. I can't imagine Cat 2 would of been more but never had Cat 2. Quote Link to post Share on other sites
Deep Purple 512 Posted March 21, 2021 Share Posted March 21, 2021 Cat 3 changed from 3 years to 2 years about 10 years ago. Cat 2 was 2 years in the previous safety regs but how long before that I don't know. Quote Link to post Share on other sites
Cantab 341 Posted March 21, 2021 Share Posted March 21, 2021 So it took 3 years to come up with that outstanding revision. There was an opportunity to follow the WS regulations and simplify the NZ regs in so many ways. Hopefully "Draft" means they are still working on it, stakeholder consultation might have been a better option given the shambles YNZ have managed to make of it themselves. 1 Quote Link to post Share on other sites
armchairadmiral 411 Posted March 22, 2021 Share Posted March 22, 2021 Yep, thats why yet another competitor stopped racing. Over regulation. Amazingly we continued to sail those same waters in similar conditions and haven't had an issue. And without the security of other competitors around us ! Quote Link to post Share on other sites
