Tillsbury 5 Posted July 22, 2021 Share Posted July 22, 2021 I agree that external covers screwed on aren't going to make that much difference, although if they were paired with similar covers internally and bolted together that would be a start. Still seems to me that storm covers that *aren't* attached would be more useful, particularly once a window broke, as long as you had a simple method (such as channel) to fit them afterwards. Tricky though since you don't know what you're going to lose as well as the windows. Simpler I think just not to have windows over 2 square feet on your boat. 2 Quote Link to post Share on other sites
aardvarkash10 969 Posted July 22, 2021 Share Posted July 22, 2021 2 minutes ago, Tillsbury said: I agree that external covers screwed on aren't going to make that much difference, although if they were paired with similar covers internally and bolted together that would be a start. was just about to write this. Double glazed (separate sheets into a rebate on inside and outside) during build could acheive the same thing. Quote Link to post Share on other sites
2flit 52 Posted July 22, 2021 Share Posted July 22, 2021 13 minutes ago, aardvarkash10 said: was just about to write this. Double glazed (separate sheets into a rebate on inside and outside) during build could acheive the same thing. and how do you stop condensation between the layers? After being on that passage from Tonga in 2019 with winds steady 45 gusting 65... I can't even begin to imagine going out on deck with a piece of plywood, it's just nuts. And the idea of only sending some screws thru whatever your skin and foam core might constitute... is an absurd idea on that sort of hull construction. This story (for me) is a sobering reminder of how vulnerable salon windows have become in modern yacht design. Even our Farrier with a 4 to 8 cm rabbited recess and screws every 24cm seems wholly inadequate. 1 Quote Link to post Share on other sites
Fogg 427 Posted July 22, 2021 Share Posted July 22, 2021 27 minutes ago, Tillsbury said: Simpler I think just not to have windows over 2 square feet on your boat. Not simple for people like me. Quote Link to post Share on other sites
ex Elly 197 Posted July 22, 2021 Share Posted July 22, 2021 43 minutes ago, Black Panther said: So the significant change is the covers,are now fitted rather than carried? Also: - liferaft to be securely fitted, - drogue use needs to be practised by skipper, - don't sail in the SE quadrant of a low as that is the worst place (southern hemisphere) Quote Link to post Share on other sites
Black Panther 1,595 Posted July 22, 2021 Share Posted July 22, 2021 3 minutes ago, Fogg said: Not simple for people like me. Some are apparently adding a mullion and halving window size. It's in another thread somewhere. That might be a solution that would be better than covers and more aesthetically pleasing. Quote Link to post Share on other sites
Black Panther 1,595 Posted July 22, 2021 Share Posted July 22, 2021 3 minutes ago, ex Elly said: Also: - liferaft to be securely fitted, Kinda obvious ,( says he who lost one in a rollover). 3 minutes ago, ex Elly said: - drogue use needs to be practised by skipper, Kinda obvious 3 minutes ago, ex Elly said: - don't sail in the SE quadrant of a low as that is the worst place (southern hemisphere) Tricky one. We all try to avoid such things, but in my humble opinion it will get you one day. Therefore if the boat and crew can't handle 60+kn and the sea state it generates then they are not fit for purpose. Quote Link to post Share on other sites
Black Panther 1,595 Posted July 22, 2021 Share Posted July 22, 2021 11 minutes ago, 2flit said: and how do you stop condensation between the layers? After being on that passage from Tonga in 2019 with winds steady 45 gusting 65... I can't even begin to imagine going out on deck with a piece of plywood, it's just nuts. This. Whatever your plan is it needs to be implemented way before it is necessary. 11 minutes ago, 2flit said: And the idea of only sending some screws thru whatever your skin and foam core might constitute... is an absurd idea on that sort of hull construction. This story (for me) is a sobering reminder of how vulnerable salon windows have become in modern yacht design. Even our Farrier with a 4 to 8 cm rabbited recess and screws every 24cm seems wholly inadequate. 1 Quote Link to post Share on other sites
waikiore 405 Posted July 22, 2021 Share Posted July 22, 2021 The worrying note in the report refers to the deck and cabin noticeably flexing prior to the final knock down, this and the unknown state of the keel attachment along with the open forward hatch undoubtedly contributed to the fast sinking of an otherwise well equipped yacht being sailed by more than averagely experienced crew. Quote Link to post Share on other sites
marinheiro 352 Posted July 22, 2021 Share Posted July 22, 2021 per BP request, reposting from my MNZ Report post: The report tells it how it happened, based on my discussions with Pam Pedersen and the wife of one of the other crew members. I had been in regular email contact with Pam and Stu prior to their departure as they had found me a crew member for my passage back from New Cal. I believe their departure date was to some extent set by the arrival of their crew. Riada and several other yachts had left Fiji the previous week and had a fast if bumpy passage with an easterly wind pattern. When i saw on their tracker they had departed Fiji I had a look at the weather during the period of their passage and it was quite clear just from Windy that there was some ugly weather forecast close to NZ. My opinion is they did not receive good weather advice. When I sailed from New Cal I used Bruce Buckley from Australia and his info was spot on. Re storm coverings, until the rule change they only had to be carried, not fitted. If they had been fitted to Essence, they probably would not have stopped the windows popping but they would have obviously significantly reduced the open area for water to enter. remember also the forard hatch had come open , that would have been 60 x 60cm so would have let alot of water in. A tragic loss Crew Bruce Goodwin has written a book of the event https://www.thebestlittlebookstore.nz/product-info.php?The+Final+Voyage+of+the+Essence-pid420.html Quote Link to post Share on other sites
CarpeDiem 432 Posted July 22, 2021 Share Posted July 22, 2021 1 hour ago, Black Panther said: Some are apparently adding a mullion and halving window size. It's in another thread somewhere. That might be a solution that would be better than covers and more aesthetically pleasing. Looking at the picture it's already are separated internally with Muntins, and they don't look large enough to be a issue. It's the size of the internal hole, not the size of the covering glass that matters. in the interests of sharing... Mullion's are inside and outside and split the glass entirely so you have two pieces of glass. While Muntin's are only on the inside and provide structural support to the window frame, but the glass is continuous over the Muntin. 1 Quote Link to post Share on other sites
Black Panther 1,595 Posted July 22, 2021 Share Posted July 22, 2021 I learn something new everyday. Never heard of a muntin before. Quote Link to post Share on other sites
CarpeDiem 432 Posted July 22, 2021 Share Posted July 22, 2021 15 minutes ago, Black Panther said: I learn something new everyday. Never heard of a muntin before. neither had I till last week when I went down the - "my windows are too big" rabbit warren Quote Link to post Share on other sites
DrWatson 381 Posted July 22, 2021 Share Posted July 22, 2021 I guess I'll be measuring the window size on FIREFLY week from now. 50x37cm... I assume that this doesn't apply to hatches which are by definition different, but which are subject to the same forces. If one was to fit external wash boards to windows like those on Firefly, it would undoubtedly offer a good grip for a heavy wave to exert extreme tearing and ripping force on the cabin structure at the mounting points of any external covering boards. I think this a blanket rule that possibly works well for some wooden boats, solid glass boats etc. where windows are retained by multiple screws, but is a disaster for modern composite sandwich designs, which are extremely stiff, but could suffer badly from any "externally mounted, point attached" covering board system. An external covering applied to a zone not engineered for such point loads could easily help tear your cabin apart. On vessels with glued in windows, the rule should likely be nuanced to take into account the size of the glue surface area to window area ratio, the thickness of the window (and material type), and the type of construction of the deck/cabin and window frame rebate. Another point, the article states a quote: "The amendment thus avoids the need for crew to fit storm coverings at sea, which can be a difficult and dangerous undertaking, particularly in heavy seas." Yes, it can be dangerous, but, given that logic, no one should be doing anything on deck in heavy weather, so you should go to sea already towing your drogue or your para-anchor, make sure you never sail with more than your third reef, the foredeck should be fenced off with warning signs, and the use of extras strictly forbidden. Yes I know I'm taking it a bit far, but... Quote Link to post Share on other sites
DrWatson 381 Posted July 22, 2021 Share Posted July 22, 2021 4 hours ago, Black Panther said: I learn something new everyday. Never heard of a muntin before. likewise. Quote Link to post Share on other sites
Ex Machina 368 Posted July 22, 2021 Share Posted July 22, 2021 5 hours ago, Black Panther said: I learn something new everyday. Never heard of a muntin before. Isn’t that what munters do on the weekend ? 1 Quote Link to post Share on other sites
aardvarkash10 969 Posted July 22, 2021 Share Posted July 22, 2021 7 hours ago, 2flit said: and how do you stop condensation between the layers? what aircraft do - tiny little holes drilled through the inner glazing to provide venting. Quote Link to post Share on other sites
Island Time 1,246 Posted July 23, 2021 Share Posted July 23, 2021 I've read the MNZ report. 1stly let me again express my condolences to the families concerned. We all need to see this as a learning experience, to try to prevent another similar event at a later time. IMO most core construction vessels cannot simply screw "storm shutters" to a window surround without weakening the whole area. External shutters screwed on would have made little difference in this situation unless they where actually in contact with the window material or frame, and hence provided additional support to resist the internal pressure. A few screws in a composite structure are not very strong! Also, why are YNZ and Maritime NZ referring to books about heavy weather techniques written 50 years ago, when composite construction was not even invented, and boats were very different? Finally, IMO, to run downhill without a drogue in conditions where the breaking part of the wave is more than 30% of your waterline length, in a boat that cannot exceed wave speed is almost certain to end in a broach and knockdown or roll over. 4 Quote Link to post Share on other sites
Fogg 427 Posted July 23, 2021 Share Posted July 23, 2021 My overriding takeaway from this incident and report is a sense of unease that this continues a culture of “An accident happened and therefore something must be done to prevent a recurrence.” For sure do an investigation but don’t automatically assume there must always be a conclusion that a new guideline / practise / rule / law must follow. Sometimes that is the right outcome especially when a glaring omission is identified which can be readily implemented. But in cases like this I don’t think that’s necessarily the case. The giveaway for me is how impractical the recommended solutions are. Question: how many other countries have a similar requirement? How many international cruisers arrive in NZ with their windows boarded over in this way? 2 Quote Link to post Share on other sites
Black Panther 1,595 Posted July 23, 2021 Share Posted July 23, 2021 To the best of my knowledge NZ is the only country. And Fogg's post sums up my reaction to the report. And IT's post alludes to another problem: an unwillingness to criticize. This is understandable as these are real people with friends and families. I don't know the answer to that one. Quote Link to post Share on other sites
