All Activity
- Yesterday
3.43 The underwater topography off Murimotu Island matches the wave performance observed by the passenger. From seaward, the seabed off Murimotu Island slopes steeply from 50 to 10 metres water depth over 0.7 nautical miles (1300 metres). The seabed slopes very steeply from 30 to 2 metres water depth (see Figure 15). To the observer on the Enchanter’s aft deck a larger wave would have begun visibly peaking in the distance, with a sharp rise when the wave met with the 10-metre contour. 3.44 This analysis of the wave form supports the hypothesis founded on the EPIRB data, that the capsize o
Oh Dear, that doesn't look good for him.
Here is the TAIC Final report. Skippers route is shown on page 28. Couple of pages down is the EPIRB track. MO-2022-201 Charter fishing vessel, Enchanter, capsize, North Cape, New Zealand, 20 March 2022 (taic.org.nz)
TAIC states "about as likely as not" as in 50:50 the Enchanter strayed into shallow water. That is a highly uncertain statement as to exactly where the Enchater was. It is 50:50 the skipper had the boat where he said, in safe deep water, and it was an actual rogue wave that got it, not shallow water effect. Just like the Essence off BoI. 50:50 Isn't our justice system based on 'reasonable doubt'? Why it happened The Enchanter should easily have coped with the sea conditions off North Cape at the time of the accident. However, it is about as likely as not the vessel had str
Many of the points posted here are opinions. Having a difference of opinion is not a criminal matter. Generally the criminal test is gross negligence. The prosecution are saying he should not have been within 3 miles of land, but psyche has confirmed there is no rule regarding this. His ship was apparently in good order, and approved for the area it was operating in. He checked the forecast regularly, so not like he was sailing blind. The only paperwork he didn't have was an expired first aid certificate, not directly contributable to the incident. So it's not like he was tryin
Do you know if that integrates OK with a Nexus system?
blue polytarp and ahollow log
The annual alarm has been sounded again. https://www.newshub.co.nz/home/new-zealand/2024/05/iwi-and-researchers-sound-alarm-over-rms-niagara-s-oil-threat-to-hauraki-gulf.html
There are certain foil wraps that were not available for our Pogo. Too dark. By boat 50(?) they had changed the foam sandwich (I think) and a palette of slightly darker colours was added - still no black or dark blue, tho, afaik
Area in green box is where vessels often shelter under North Cape Area in red box is a shallow area which in certain conditions will cause waves to rear up / amplify. As you can see it would be very tempting to cut the corner and go over the shallow patch as you get to the sheltered anchorage quicker... However it would be much safer making a much wider rounding
His cavalier attitude, business hardline, are not attributes to be encouraged in skippers, particularly commercial. If this is not addressed in this tragedy it is just going to happen again. "At the end of the day, the responsibility rests with the skipper. It's a lot resting on your shoulders and most times - touch wood - you get it right. On the occasions you don't, there will be a price to pay." That price was significant, and the repercussions need to be also. The loss of five punters lives was directly attributable to the skippers MO. Ignore all the indicators at your per
A B&G WS320 wireless wind MHU with a NMEA2000 interface is $1009 + GST....
My current mhu is wireless anyway, so I'm up for running a new wire regardless. Since the mhu packed up, I've been going old school and just estimating the wind strength based on the feel on my face and the state of the sea. Given I'm probably looking at $2k to replace the wind transducer, I might just continue with old school wind speed for a bit. The AP goes find on course heading. We have a powerful hydrualic ram on the back of our tiller steer (37fter), and that is the main thing for me at the moment. Noting I've not raced for a few years so the need for fancy lectronics is dimin
There are several ways of integrating a Garmin gWind into the Nexus system. The first is as you mention the wired gWind mhu which comes complete with the GND10. The disadvantage is you need to run a new cable down the mast as the connector on gWind is different to the connector on the Nexus mast cable. The second option is Garmin make a small adaptor cable that goes between the gWind mhu and the Nexus mast cable. The Nexus mast cable needs to be moved from the Wind port on the server to Nexus/instrument bus port.
And a big ground swell.
Are you saying they ran aground now? I can't keep up.
Hi, I have a fair amount of coastal sailing experience and are looking to possibly do the passage crossing to fiji etc. Im a fit and healthy 42 year old with decades in a building and mechanical environment. Extremely comfortable on and in the ocean. Easy going and happy working with a team or solo. Happy to look at any opportunity to get some open water experience.
That would put them in or very close to shallow water
I've been looking at that GND10, it is that unit that makes the gWind integrate with the Nexus system. It comes with the wired gWind. Noting that the riggers warned me off putting another wireless unit on, and the retailer wont even sell them, saying they (the Garmin gWind) are complete sh*t, so if I proceed it will have to be a wired unit. Interestingly I've not had any issues with my Nexus Multi displays. Blowing the FETs on the AP course controller (the computer thingee tucked away in a locker) was due to malfunctions of the autopilot ram. On one occasion it decoupled from the tiller a
Except that there was no "rogue wave" just the shallow bottom.
I currently have a hybrid Nexus/N2k system. One of my NX2 multis failed so I decided to replace it with a B&G Vulcan 7. To get the Nexus wind, speed and depth data to the Vulcan 7 I installed a Garmin GND10 which is a gateway/converter between the Nexus bus and N2K and vice versa. The GND10 needs to be programmed for data direction e.g I have the GPS data from the Vulcan feeding the Nexus bus. I was also looking at what to do when my transducers fail. The Silva/Nexus/Garmin 43mm thru hulls are a bit of an orphan but I don't really want to replace the thru hull fittings. Garmin still d
Ok, that's a much better heading sensor than the usual ones on an AC12! So Yes, a NAC2 or three would be an improvement. However, I have had customers complain about them as well, and also H5000 pilots. All the pilots need to be setup correctly, usually by more than just autotune. With the AC12 and the NAC series, the low and high speed settings can be used to have normal and running settings, rather than low and high speed. S turns are often the result of too much rudder gain, but can be wrong counter rudder settings as well. There is a pretty good description of this and how to set
This is from B&G. So if you want motion correction, has to be a Hercules or H5000...
If kept in good nick, they are pretty amazing boats. Great cruiser, great racer. Nearly as good as a Thompson 38.
